11-09-2008 01:33 PM - edited 03-06-2019 02:23 AM
I'm just starting to learn my IP protocols. I have just started on RIP version 2 with just 2 routers. Once I can get these 2 router ping each other I will add a 3rd router.
Attached are my 2 routers configs, I just want to ping the both LAN's which are the loopback interfaces to prove the routing is all working. It all worked with static routing.
Also any useful debug commands would be great, as I'm not sure if the RIP updates are being sent to either router.
11-09-2008 03:10 PM
try to make ur config as following
router1:
router rip
version 2
network 10.0.0.0
network 172.30.30.0
no auto-summary
router 2
interface Loopback0
ip address 192.168.4.99 255.255.255.0
interface FastEthernet0/0
ip address 192.168.3.99 255.255.255.0
router rip
version 2
network 10.0.0.0
network 192.168.3.0
network 192.168.4.0
no auto-summary
good luck
if helpful Rate
11-10-2008 03:38 AM
1.) I have noticed you added the fa0/0 on router 2 to the network list eventhough it is shutdown, do I need to do the same for Router 1's fa0/0 - "network 192.168.2.0"?
2.) 0n router 1 I try to add "network 172.30.30.0" but it defaults to "network 172.30.0.0"
3.) the clock rate only has to be set on the DCE router? (Router 2)
11-10-2008 05:41 PM
No, I believe he was illustrating that you have duplicate IP addresses in the loopback interface and the LAN interface. Your initial message indicated you wanted to test connectivity between LANs, on this case, it seems you want to test connectivity between loopbacks - which is fine but it differs from the initial message. As long as you keep the LAN interface is shutdown mode, you should be able to ping between loopbacks with your provided config.
Expected behavior under router rip process. It defaults to its classful network.
On back-to-back connections, YES.
HTH,
__
Edison.
Please rate helpful posts
11-09-2008 10:00 PM
ok Hi first of all,
Router A
connected to 10.x.x.x & 175.x.x.x
RIP command should be
router rip
ver 2
net 10.x.x.x
net 175.x.x.x not sure of the subnet
router rip
version 2
network 10.x.x.x
network 192.168.2.0
dont forget to config your bandwidth on the router with the clock speed
