2811 router sits at ROMMON prompt after power outage.
Nov 9th, 2008
When the 2811 router is turned OFF and ON it does auto boot correctly every time. No problem there.
But when there is a power failure / power recovery the router goes and sits at ROMMON prompt.
I have to find out the config-reg values etc. but I can't believe problem to be with config-reg because customer tells me that it boots everytime fine when router power is turned OFF and then ON. The problem is just after power outage. I can't see the difference.
Customer said that he found a Field Notice (I am still searching for that Field Notice) where the solution to this problem is to upgrade the ROMMON which he has done but he still has the same problem even after upgrading teh ROMMON.
Overall Rating: 3.5 (2 ratings)
Richard Burts Sun, 11/09/2008 - 16:54
The symptoms as described are quite strange. I am not sure why the recovery from a power outage would be any different from a power off/power on - unless perhaps it is the amount of time that the router was powered down.
I would suggest that the first thing to do is to very the setting of the config register
cisco24x7 Sun, 11/09/2008 - 18:42
The issue has to do with the firmware in the
ROMMON. I ran into the exact same issue you
described on the Cisco 2851 router running IOS
code c2800nm-advipservicesk9-mz.124-16.bin.
You need to upgrade the firmware code to
C2800NM_RM2.srec.124-13r.T5. That will fix
your problem.
Easy right?
glen.grant Sun, 11/09/2008 - 17:02
You probably have hit it on the head about the rommon . I think we have seen that once or twice in those models but we have dial backup in most places so we just issue a boot command and it loads. I think it happens when you get a quick power hit where it doesn't go all the way down properly and then the power comes back on quickly. It may be field notice 62127 , which says
# The router may fail to auto-boot its flash image:
Note: This type of failure as shown in 1.a. and 1.b has been seen and documented:
Readonly ROMMON initialized
boot: cannot open "flash:"
boot: cannot determine first executable file name on device "flash:"
cxxxx processor with 524288 Kbytes of main memory Main memory is configured
to 64 bit mode with ECC enabled
rommon 1 >
The above has been seen on a Cisco 3800 router.
System Bootstrap, Version 12.3(8r)T, RELEASE SOFTWARE (fc1) Technical
Support: http://www.cisco.com/techsupport Copyright (c) 2004 by Cisco Systems,Inc.
PLD version 0x10
GIO ASIC version 0x127
At this point, the system cannot execute from boot flash with the affected Compact Flash when the software enables the quick switches.
The above has been seen on a Cisco 2801 router.
# A router reboot may be triggered from a momentary system power resource overload. This reboot may or may not fail due to the symptom described in scenario #1 directly above.
# System accesses to compact flash for certain operations like CLI compact flash queries, TFTP download, or IOS VLAN database storage updates may not be complete. Interruption of services requiring compact flash will result as if compact flash were removed from the system.
Following are two failure messages one can get from console output with a failed compact flash:
astanislaus Sun, 11/09/2008 - 18:49
I have the correct Bootstrap Version:
------------------ show flash: all ------------------
-#- --length-- -----date/time------ path
1 44909204 May 15 2008 10:55:32 +10:00 c2800nm-entservicesk9-mz.124-11.XW2.bin
2 39682544 May 15 2008 11:04:18 +10:00 c2800nm-entservicesk9-mz.124-11.XJ4.bin
3 1623191 Oct 22 2008 07:14:18 +10:00 C2800NM_RM2.srec.124-13r.T6
------------------ show version ------------------
Cisco IOS Software, 2800 Software (C2800NM-ENTSERVICESK9-M), Version 12.4(11)XW2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Mon 02-Jul-07 18:13 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T6, RELEASE SOFTWARE (fc1)
twb02rtr01-2811 uptime is 6 days, 3 hours, 53 minutes
System restarted at 07:15:59 AEST Tue Nov 4 2008
System image file is "flash:c2800nm-entservicesk9-mz.124-11.XW2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 2811 (revision 53.51) with 251904K/10240K bytes of memory.
Processor board ID FHK0924F21R
2 FastEthernet interfaces
1 HSSI interface
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
125440K bytes of ATA CompactFlash (Read/Write)
Partial Config:
boot system flash:c2800nm-entservicesk9-mz.124-11.XW2.bin
boot system flash:c2800nm-entservicesk9-mz.124-11.Xj4.bin
