Cisco 871 W
Nov 9th, 2008
Sorry, i'm really new to cisco world.
-Can I disable the wireless function of this router Cisco 871 W. What i want to do is to turn off the wifi signal and use cable connection only.?
Thanks.
rmcarthur Mon, 11/10/2008 - 01:21
  • Bronze, 100 points or more
Hi Yusof, yes you can. From the cli go into the radio interface, DOT11 0 and issue a shutdown command.
Router#conf t
Router(config)#interface dot11 0
Router(config-if)#shutdown
Router(config-if)#end
Router(config)#end
Router#wr mem
Hope this helps
