Spanning Tree
Nov 9th, 2008
hi,
I have 6506 as a core and 3750E as an access layer switches, they are connected with 10G and 1 G uplink. The following is the configuration.
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
spanning-tree uplinkfast
spanning-tree backbonefast
when i issue the command show spanning-tree, the problem is with the cost, it shows cost starting with 3002, i have read that 10G link cost is 2 and 1G link cost as 4. The output of show spanning tree. is as follows.
VLAN0001
Spanning tree enabled protocol ieee
Root ID Priority 49153
Address 0017.0f4a.69c0
This bridge is the root
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 49153 (priority 49152 sys-id-ext 1)
Aging Time 480
Uplinkfast enabled
Interface Role Sts Cost Prio.Nbr Type
Gi1/47 Desg FWD 3004 128.47 P2p
Gi1/48 Desg FWD 3004 128.48 P2p
Te4/5 Desg FWD 3002 128.389 P2p
Te4/6 Desg FWD 3002 128.390 P2p
Po1 Desg FWD 3001 128.1665 P2p
Po2 Desg FWD 3001 128.1666 P2p
can you explain me the why the cost is 3002 on Ten gig link.
Collin Clark Mon, 11/10/2008 - 07:39
  • Purple, 4500 points or more
The spanning tree pathcost is probably set to long (it should be).
Hope that helps.
John Blakley Mon, 11/10/2008 - 08:06
You have uplink fast enabled which automatically bumps the cost up to avoid a spanning-tree loop if recalculations happen. Your bridge priority will also be set to 49152 on that switch, with your extended-id added to it. (Extended-id is the VLAN number.)
--John
