CME and Cisco IOS Software Compatibility
Nov 9th, 2008
Hi all, I have a small issue in regards to CME.
I have a 2811 router running c2800nm-advipservicesk9-mz.124-22.T.bin and according to the Compatibility Matrix, http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm , I require Cisco Unified CME 7.0(1).
However, when I go to the Downloads section, the latest version I can find is:
cme-124-20T1.zip - CME 7.0/4.3 files for IOS 12.4(20)T releases. This new zip file includes updated CME GUI 7.0.0.1.
Does anyone know where I can find the correct version of software? Or hasn't it been released yet? I would say it has seeing as though it says so in the Compatibility Matrix, but I could be wrong.
Any information would be greatly appreciated. Thanks everyone.
AJAZ NAWAZ Mon, 11/10/2008 - 00:21
  • Silver, 250 points or more
That version in not available at this time. In due course it will appear for download and only Cisco can say exactly when that will be.
In the meantime 12.4-20T1 is the way to go, and i can tell you from experience the code seems pretty stable. As you know evaluate this code in your own environment prior to deployment into production.
Ajaz
voiper_99 Mon, 11/10/2008 - 14:43
Hi Ajaz,
Thanks for the information, it is much appreciated.
I will temporarily downgrade to 12.4-20T1 until the new software is released.
