Jon Marshall Mon, 11/10/2008 - 00:53
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Vinoth
This is a 2 step process.
1) Find the mac-address that is connected to the port ie.
sh mac-address-table interface gi0/2
2) Then you need to log on to the device that does the routing for this device which will either be a router or a L3 switch
sh arp | include
Jon
gnijs Wed, 11/12/2008 - 06:33
  • Bronze, 100 points or more
Or if you have ip dhcp snooping enabled, its easy:
sh ip dhcp snooping binding
John Blakley Wed, 11/12/2008 - 07:03
  • Purple, 4500 points or more
I do it the way Jon describes. It works great.
Also a tip, if you're trying to find out where other switches connect to your core (assuming you're doing this on the core), you can do a sh int to find the mac address of that switchport, and then look for that mac address on the other switch to find out what port it connects to. Works well. I just had to map out my network doing it this way.
--John
