Giuseppe Larosa Mon, 11/10/2008 - 05:17
  • Hall of Fame,
    Founding Member
>> Even after reboot or issuing the
"clear line vty" the vty lines are not getting cleared.
line vty are useful to telnet to the device,
clear line vty doesn't delete the line vty it just frees it if busy.
However, after a reboot / reload you should see only one line vty used the one you are on:
see
RT-RM-FONTBORG-RT-1#sh users
Line User Host(s) Idle Location
* 66 vty 0 g.larosa idle 00:00:00 10.55.49.56
67 vty 1 g.larosa idle 00:00:07 10.55.49.56
Interface User Mode Idle Peer Address
RT-RM-FONTBORG-RT-1#clear line vty 1
[confirm]y [OK]
! again with clear line
67 vty 1 g.larosa idle 00:00:04 10.55.49.56
RT-RM-FONTBORG-RT-1#clear line 66
% Not allowed to clear current line
RT-RM-FONTBORG-RT-1#clear line 67
[confirm]y [OK]
Hope to help
Giuseppe
mohindersingh Tue, 11/11/2008 - 04:34
Hi Buddy,
its lil funny, but do your user-Id have rights to clear the vty line..smtime we miss small things
Mahi
troswellCCO Tue, 11/20/2012 - 13:16
Depends if you're accessing using your router as a Terminal Server over Octal cable.
Try "disconnect" command instead of "clear".
Router1#sh sess
Conn Host                Address             Byte  Idle Conn Name
*  1 dogg              192.168.239.1        151    14 dogg
Router1#clear line 1
% Not allowed to clear current line [OK]
Router1#
Router1#disconnect 1
Closing connection to dogg [confirm]
Router1#sh sess
% No connections open
Router1#
