didyap Sat, 11/15/2008 - 10:18
  • Silver, 250 points or more
Use the guard-interval configuration mode command to configure the The 802.11n guard interval. The guard interval is the period in nanoseconds the radio listens between packets. Two settings are available: short (400ns) and long (800ns).
This example shows how to set a long guard interval on a 2.4-GHz 802.11n radio:
ap#config terminal
ap(config-if)#interface dot11radio0
ap(config-if)#guard-interval long
ap(config-if)#end
ap#copy running-config startup-config
I hope it may help you.
krishanmistry Sat, 11/15/2008 - 13:30
Thanks Didyap
I was aware of the configuration for an IOS AP however I am looking for the configurations on a controller based solution.
Many Thanks
grzegorz.ciolek Sat, 11/15/2008 - 13:59
Which value do you need. As far as I remember (video from networkers) default in controller is 400ns.
Cheers
Greg
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
