Displaying company name on IP Phone
Nov 10th, 2008
On 7940 IP Phone, there is black strip on the top that displays time, date and ext no. I want to display our company name on that strip. Does anyone know how to do that?
Rob Huffman Mon, 11/10/2008 - 06:34
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Abhijit,
This is available in CME only, not CCM at this point in time. This would be on the "lower" banner location;
Have you looked into using this CME Feature?
System Message Display
The System Message Display feature allows you to specify a custom text or display message to appear in the lower part of the display window on display-capable IP phones. If you do not set a custom text or display message, the default message "Cisco Unified CME" is displayed.
When you specify a text message, the number of characters that can be displayed is not fixed because IP phones typically use a proportional (as opposed to fixed-width) font. There is room for approximately 30 alphanumeric characters.
The display message is refreshed with a new message after one of the following events occurs:
Busy phone goes back on-hook.
Idle phone receives a keepalive message.
Phone is restarted.
The file-display feature allows you to specify a file to display on display-capable IP phones when they are not in use. You can use this feature to provide the phone display with a system message that is refreshed at configurable intervals, similar to the way that the text message feature provides a message.
The difference between the two is that the system text message feature displays a single line of text at the bottom of the phone display, whereas the ***system display message feature can use the entire display area and contain graphic images.
SCCP: Modifying System Message Display
To modify the system message display on phone screen, perform the following steps.
SUMMARY STEPS
1. enable
2. configure terminal
3. telephony-service
4. system message text-message
5. url idle url idle-timeout seconds
6. end
System File Display: Example
The following example specifies that a file called logo.htm should be displayed on IP phones when they are not in use:
telephony-service
url idle http://www.abcwrecking.com/public/logo.htm idle-timeout 35
From this good CME doc;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmelabel.html#wp1032353
Hope this helps!
Rob
cjbaker Tue, 01/27/2009 - 19:53
Just use the "description " command for the main ephone-dn on the phone. So if you have:
ephone-dn 1
description XYZ Company
number 3000
ephone 1
mac-address 0000.0000.0000
button 1:1
The phone should display on the top black bar of the phone:
" XYZ Company"
