11-10-2008 06:40 AM - edited 03-13-2019 05:49 PM
My voice is muffled to others when I use the headset. Any solution to this problem? Using a new Plantronics headset. Is there a Cisco Headset for this model?
11-10-2008 06:46 AM
Hi Linda,
What model of Plantronics Headset are you using? We use many corded models like the H-91, H-101, H-171's. The one part you will need which is required for all "corded" Plantronics Headsets (to go from Headset Jack on 7970 to "Quick Disconnect" on Headset) is a special Cord (shown below);
Part#Amp-26716-01
If these are Cordless Headsets like the CS-55 or CS-70 Series make sure you set the Compatibility wheel on the Base Station to #4
Hope this helps!
Rob
06-27-2014 08:44 AM
Hello Idenis001 or anyone else with the same issue. The silly question, is the mic to close to your mouth. I know that's dumb but it had to be asked. Next, I would ask if your headset has ever provided a clear sound or does it become muffled off and on. Is your headset model compatible with your phone model? To see an updated list of compatible headsets for the Cisco phones try this link.
Recommendations:
1. Check your compatibility.
2. If it's cutting in and out, check your warranty and trouble shoot with Plantronics or get replacement.
