(SRST) Number Expansion During System Transfer
Answered Question
This is kinda a follow up question to my last one.
We use a 10 digit dial plan with 5 digit abbreviated dialing within our sites. When is SRST we can transfer a call to the full ten digit extension it works, but our users would like to use the 5 digit extension.
Can I do this with a translation rule or something similar?
Thanks in advance for your help
Here is my current config
call-manager-fallback
max-conferences 10 gain -6
transfer-system full-consult
ip source-address xxx.xxx.xxx.xxx port 2000
max-ephones 40
max-dn 80
transfer-pattern .T
default-destination 8002717060
call-forward busy 8002717060
call-forward noan 8002717060 timeout 30
Correct Answer by Chris Deren about 8 years 5 months ago
You can use a translation profile and apply it to SRST such as:
voice translation-rule 1
rule 1 /^7/ /80027177/
voice translation-profile 4-DIGIT-SRST
translate called 1
translation-profile incoming 4-DIGIT-SRST
Chris
Overall Rating: 0 (3 ratings)
Brandon Buffin Mon, 11/10/2008 - 08:31
  • Purple, 4500 points or more
One way to do this is with the "num-exp" command. So if you want to dial 1234 and translate it to 1234567890, you could configure "num-exp 1234 1234567890".
Hope this helps. If so, please rate the post.
Brandon
Brandon Buffin Mon, 11/10/2008 - 10:56
So, you can dial 17... directly and it works, but if you receive a call, press the transfer key and dial 17..., the call fails? Do you get fast busy?
Brandon
Correct Answer
Chris Deren Mon, 11/10/2008 - 09:20
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
translate called 1
Chris
Chris, I set this up but I wont be able to test till tomorrow because the gateway is in South Africa and they are out for the day.
Here is what I did.
voice translation-rule 2
rule 1 /\(^17...$\)/ /80027\1/
voice translation-profile SRST_Exp
translate called 2
translation-profile incoming SRST_Exp
