"!!! WARNING: The switch is not usable !!!" message on c3750
Nov 10th, 2008
Hi all,
I have 2 Catalysts 3750 in a stack, with IOS version 12.2(35)SE5. After switch on, one of the Catalysts gives the following messages:
POST: PortASIC CAM Subsystem Tests : End, Status Failed
POST: CAM test failed
POST Failed: disabling stack links and shutting down SDP
Unable to create l2trace server process, socket_open() failed
Press RETURN to get started!
00:00:34: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlanCannot Get the number of ports in MAC notification
00:00:35: hl2mcm_core_process: hl2mcm_install_hl2mcm_ctrl_entries() failed.
00:00:35: %SYS-3-HARIKARI: Process HL2MCM top-level routine exited
00:00:35: %SW_VLAN-4-IFS_FAILURE: VLAN manager encountered file operation error: call = ifs_read_until (header) / file = / code = 21 (Is a di
rectory) / bytes transfered = -1
-Traceback= 1E1990 1DDA40 9A0E90 998464
00:00:36: %SYS-5-RESTART: System restarted --
Is it an hardware failure?
Best regards
Stefano
Overall Rating: 5 (1 ratings)
glen.grant Mon, 11/10/2008 - 08:57
  • Purple, 4500 points or more
Yes it failed post , get an RMA from cisco and get it replaced.
Ghulam zainulabideen Mon, 05/07/2012 - 01:38
i have the same issue with my two 3750 switch. please Guide me.....
Base ethernet MAC Address: 00:17:94:8e:61:80
Xmodem file system is available.
The password-recovery mechanism is enabled.
Initializing Flash...
flashfs[0]: 354 files, 5 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 15998976
flashfs[0]: Bytes used: 7107584
flashfs[0]: Bytes available: 8891392
flashfs[0]: flashfs fsck took 9 seconds.
...done Initializing Flash.
Boot Sector Filesystem (bs) installed, fsid: 3
done.
Loading "flash:c3750-ipbase-mz.122-25.SEB4/c3750-ipbase-mz.122-25.SEB4.bin"...@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
File "flash:c3750-ipbase-mz.122-25.SEB4/c3750-ipbase-mz.122-25.SEB4.bin" uncompressed and installed, entry point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C3750 Software (C3750-IPBASE-M), Version 12.2(25)SEB4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Tue 30-Aug-05 15:47 by yenanh
Image text-base: 0x00003000, data-base: 0x00C72590
Initializing flashfs...
flashfs[1]: 354 files, 5 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 15998976
flashfs[1]: Bytes used: 7107584
flashfs[1]: Bytes available: 8891392
flashfs[1]: flashfs fsck took 1 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: PortASIC Memory Tests : Begin
POST: PortASIC Memory Tests : End, Status Passed
POST: CPU MIC PortASIC interface Loopback Tests : Begin
POST: CPU MIC PortASIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Passed
Waiting for Stack Master Election (around 30 seconds)...
POST: PortASIC CAM Subsystem Tests : Begin
HTD POST: Basic Test Failed
POST: POST Failed
driver class subsystem initialization failed
cisco WS-C3750G-24T (PowerPC405) processor (revision L0) with 118784K/12280K bytes of memory.
Processor board ID CAT1013N294
Last reset from power-on
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:17:94:8E:61:80
Motherboard assembly number     : 73-9679-09
Power supply part number        : 341-0048-03
Motherboard serial number       : CAT101301DM
Power supply serial number      : LIT100708XB
Model revision number           : L0
Motherboard revision number     : A0
Model number                    : WS-C3750G-24T-S
System serial number            : CAT1013N294
Top Assembly Part Number        : 800-25855-01
Top Assembly Revision Number    : C0
Version ID                      : V05
CLEI Code Number                : COMR100BRA
Hardware Board Revision Number  : 0x02
00:00:39: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlanCannot Get the number of ports in MAC notification
00:00:40: %SW_VLAN-4-IFS_FAILURE: VLAN manager encountered file operation error: call = ifs_read_until (header) / file =  / code = 21 (Is a directory) / bytes transfered = -1
-Traceback= 8A4200 190598 18CA50 7599A8 753BEC
00:00:41: %SYS-5-RESTART: System restarted --
Copyright (
Switch>c) 1986-2005 by Cisco Systems, Inc.
00:00:41: Unable to open UDP socket on CMP_PORT
Ghulam zainulabideen Mon, 05/07/2012 - 01:40
done.
executing...
           cisco Systems, Inc.
POST: POST Failed
Version ID                      : V05
Copyright (
glen.grant Mon, 05/07/2012 - 04:42
  Thats a hardware issue replace the faulty switch .
Leo Laohoo Mon, 05/07/2012 - 15:47
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
POST: POST Failed
As what Glen said, it's dead. Cisco TAC is your best bet.
