Denmark Numbering Plan for CallManager
Answered Question
Nov 10th, 2008
Any ideas about where I can find a Denmark based Numbering Plan for the CallManager ?
Thank you in advance
Best regards,
Pan
Correct Answer by Aaron Harrison about 8 years 5 months ago
I recently did a deployment in Denmark; I couldn't find a Cisco IDP for that country.
I used this Wikipedia link to construct my route patterns manually; no complaints yet from the users!
http://en.wikipedia.org/wiki/%2B45
Aaron
Please rate helpful posts...
Correct Answer by Jaime Valencia about 8 years 5 months ago
always mention what version you're using
Deploying Dial Plans for 5.0(1) and Later\r\nReleases
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/idp/504_423/deploy/DPLinux.html
i did a quick search there but couldn't find Denmark DP. is it a normalized dial plan?? or is it like German DP?? if it's like German dial plan we don't have any since we only create it for normalized dial plans
java
if this helps, please rate
Overall Rating: 5 (2 ratings)
Correct Answer
Jaime Valencia Mon, 11/10/2008 - 10:26
  • Cisco Employee,
  • Hall of Fame,
    2011
java
Correct Answer
Aaron Harrison Tue, 11/11/2008 - 06:12
  • Community Spotlight Award,
    Member's Choice, May 2015
Aaron
7pliapis Tue, 11/11/2008 - 09:21
Thank you for your feedback.
Yes I stumbled across that url as well.
Good to know that you have actually made
an implementation on this.
Thanks again for your time
Best regards,Pan
