DMM 4.1 Installation
Nov 10th, 2008
I have a DMM 4.1, Digital Media Encoder 1000 and Cisco digital media player 4305g.
I get to the point where I need to configure the values for the Video Portal module (http://<DMM_IP_address>:8080/DMM/) and its asks for the instance name which i dont have.. I have reinstalled it several times and it doesnt ask me what instance name I want.. what should I put In the Instance Name?
tstanik Fri, 11/14/2008 - 10:04
Complete the checklist in "Setting Up and Configuring a Video Portal Appliance." You must know the IP address and instance name for your Video Portal appliance.
For Naming or Renaming Your Video Portal
You must specify a name for your video portal. You can change the name at any time.
Step 1 Log in, select VP_CONTROL, then press Enter.
Step 2 Select INSTANCE NAME, then press Enter.
Step 3 Enter the name.
The name that you enter will be visible in the public HTTP URL that points to your Video Portal.
Step 4 When AAI shows you the name that you entered, press Enter.
