string to int conversion, in create generated prompt IPIVR
Nov 10th, 2008
IPIVR v. 4.04
I have a script, where I get from ICM, an ECC variable in string format. I need to convert this string into an integer, so that I can play a dollar amount for the callers account balance. Everything that I am trying, doesn't seem to work! I didn't think a conversion was this difficult.
Thoughts????
Overall Rating: 4 (1 ratings)
cherilynn1030 Mon, 11/10/2008 - 11:16
okay, so here is what I have in the expression editor, int.parseInt(lpamt)
The script is still throwing exceptions.
Anthony Holloway Mon, 11/10/2008 - 12:48
You should try leaving the account balance as a string and playing the prompt as:
$[accountBalanceVariable]
There is simple TTS capabilities that speak dollar amounts.
cherilynn1030 Mon, 11/10/2008 - 15:01
leaving as string and using system for prompt failed. it played nothing.
the listed integer parse didn't work either.
Ultimately, I have a string variable, that I need to convert to SOME kind of integer/float/ whatEVER to use the create generated prompt step so that I can play the account balance. I just can't believe that I can't get anything to work! It won't convert, and all I can do is laugh now, because this should be SO simple. we're supposed to cut over and I can't believe I'm failing to provide because of a simple (so I thought) conversion from string to xx.
BCOLE2007 Tue, 11/11/2008 - 19:21
Hi Cherilynn1030
I put a demo out on 1-888-210-2798
give it a call, is this what you need?
attached is the script
CRS set steps cast easiliy I didn't need the expression editor.
used a double not an integer
Let me know how it goes,
*please rate all posts
Blair
Anthony Holloway Wed, 11/12/2008 - 06:37
Too cool. Now you're making me want to get a toll free number for the same reason I got a domain name.
Thanks for your support in the forums.
BCOLE2007 Wed, 11/12/2008 - 06:55
Hey avholloway
n/p
I see your call or someone's
Your Java/CRS write up is excellent.
Blair
