Script Editor: Could Not Delete (IPCC 7.1.3)
Nov 10th, 2008
I needed to delete 'thousands' (yes I know) of backup scripts for one script. I removed almost all of them, however now I when I attempt to remove one I see the error:
Another user has changed the object. "You need to refresh and make your change again"
Does anyone have have any ideas on how I can clear this message and remove the remaning scripts?
Overall Rating: 4 (1 ratings)
smahbub Sat, 11/15/2008 - 19:27
  • Silver, 250 points or more
I think that you might be hitting the bug id CSCma16476.The word "refresh" in the error message really mean that you must reload the configuration using the reload toolbar button. Once you do that, you will be able to modify the script and save the changes.This will resolve the issue.
