11-10-2008 11:10 AM - edited 03-13-2019 05:49 PM
Hi, I have installed CUCM 6.1, and I want to know something of options, in meni "Device" I have two options "Remote Destination" and "CTI Route point"
When I use this options ? and for what?
thanks!!!
Solved! Go to Solution.
11-10-2008 11:49 AM
remote destination is for unified mobility
CTI RP is a virtual device, main use is to integrate JTAPI apps. can be used as a a routing point to reach VM or other DN in the system
java
if this helps, please rate
11-10-2008 11:49 AM
java
11-12-2008 02:12 AM
Thanks.
