SDM Config Help
Nov 10th, 2008
Hi. I have a 2811 that I want to use as a IPsec, VPN Gateway. I'm using the SDM CD that came with the software. When I run the Firewall Wizard to create my security profile, it won't let me move the slide-bar up to "High" for maximum security. It defaults at "Low"
My goal is to lock-down the "outside" interface to permit IPsec only (for my VPN tunnels). Can you recommend a "profile" that I can use to lock it down?
Many Thanks
husycisco Wed, 11/12/2008 - 10:51
Hello Peter,
You will be able to see and choose that medium and high profiles if you upgrade your IOS to latest version.
