11-10-2008 02:19 PM - edited 02-21-2020 03:05 AM
How do you usually store the backup config for your ASA/PIX config so that it's easily accessible, and yet it's secure enough? Do you simply save it to a network drive? Is there a better way to do it? I just like to know the best practice out there. It's because if I save the backup config in a network drive, people may be able to get to it and look at the config file since it's not encrypted. Any recommendation is welcome. Thanks.
11-11-2008 06:34 AM
We have our configs backed up automatically and they are stored in a database (with security). Why can't you save it to a network drive that has the appropriate permissions? You could also store them in an encrypted virtual drive using something like TrueCrypt.
Hope that helps.
11-11-2008 07:55 PM
You can use RANCID to safely and SECURELY
backing up your configuration, bar NONE.
