texasjet79 Mon, 11/10/2008 - 18:23
If you are using CCM Based Monitoring there are several items to check in Call Manager
PC Port
Span to PC Port
Enabled PC port
Check the monitoring Calling Search Space on the Line.
Anthony Holloway Mon, 11/10/2008 - 20:02
  • Purple, 4500 points or more
Also check advertise G722 on the phone in CCM. This will over ride your region settings.
dcscuba23 Mon, 11/17/2008 - 13:20
On the desktops that you are unable to monitor, go to C:\Program Files\Cisco\Desktop\bin and run the postinstall.exe. After selecting the CAD server to configure, go to the " Voip Monitor Service". Make sure that the correct IP address is showing up for the nic adapter. I had an issue after a CAD upgrade where CAD was binding to the wrong IP address thus causing an error when you try to silent monitor.
Please rate helpful posts.
