Custom Percent Allocation
Nov 10th, 2008
I need to make a percent allocation routine in IPCC 7.1.3 Script Editor which will use global variables instead of the hard coded Percent Allocation node.
Has anyone done something like this before? Can you tell me how you did it?
Thanks!
Barry
david.macias Fri, 11/14/2008 - 16:33
  • Blue, 1500 points or more
How many branches do you want to have? If you only have 2 or maybe even 3, it might be possible using the random generator and having some sort of variable passed from some external source.
david
BarryMcLellan72678 Wed, 11/19/2008 - 10:45
Thanks, for now I think I will stick with:
random()<=(Global.Variable/100)
Would be nice if you could use a global variable in a percent allocation node though!
Barry
