CSM and site to site VPN's to unmanaged devices
is anyone managing Site to Site IPSec VPN's between a managed firwall and a 3rd party (unmanaged) firewall with Cisco Security Manager? From the documentation (and testing) it appears that VPN's between managed and unmanaged devices are supported (See "Adding Unmanaged Devices to Your VPN Topology" from http://www.cisco.com/en/US/docs/security/security_management/cisco_security_manager/security_manager/3.2.1/user/guide/vpchap.html). Unfortunately CSM generates the error "Security Manager does not support policy discovery for unmanaged devices" when running Policy -> Discover VPN Policies, so all Site to Site VPN's must be defined manually. This is a major process for me as I need to import a large number of devices and VPN's into CSM. Is anyone aware of an easier way to accomplish this?
FYI - The manual process I've bee using is as follows:
1) Discover managed device.
2) Discover unmanaged device (using Add New Device wizard, and unselect "Manage in Cisco Security Manager")
3) Add an interface to the unmanaged device with correct peer IP address. This seems to be required otherwise when you submit changes an error occurs.
4) Create Site to Site VPN.
5) Submit and deploy.
Note that when deploying, CSM still wants to deploy to the unmanaged device (which seems strange to me as the device is not managed by CSM).
If anyone has any come across these issues I'd like to know if you have any workarounds.
Matt Moore
sadbulali Fri, 11/14/2008 - 11:13
  • Bronze, 100 points or more
The steps you have provided for adding unmanaged devices is the only way of doing the same.For successful VPN discovery, the following prerequisites must be met:
1) All devices participating in the VPN must be added to the Security Manager inventory.
2) You must provide Security Manager with some basic information about the VPN. The VPN discovery wizard prompts you for the following information:
-VPN topology (hub and spoke, point to point, full mesh)
-VPN technology (Regular IPsec, IPsec/GRE, GRE dynamic IP, DMVPN, Easy VPN)
-Devices in the VPN and their roles (hub/spoke)
-Source of the VPN configuration. The VPN can be discovered directly from the live network or from Security
3) Manager's Configuration Archive.
4) Each device in the VPN must have a crypto map associated with a physical interface.
5) Each PIX 6.3 or ASA 5505 client device in an Easy VPN topology must have a vpnclient configuration.
spasternacki Wed, 06/10/2009 - 05:27
Matt,
Have you managed to get this automatic import process working? Or maybe you have found better workaround?
Anyone else came across this issue?
Sebastian
