System Temperature issue
Nov 10th, 2008
I am using ciscoEnvMonTemperatureStatusValue
but all the devices are showing a constant 30 for Min Max Average.
Plz Help
dany.datacraft Mon, 11/10/2008 - 23:57
Hmm... 30 degrees Celcius looks like a good value to me. What are you expecting?
darren-carr Tue, 11/11/2008 - 00:13
You think that is bad some of mine are 40+
We have poor ventilation in this rack.
Most of our switches even in well air-conditioned comms rooms are constant at around the 30 mark
sanjay.ccie Tue, 11/11/2008 - 00:31
30 is good! But the problem is that it is 30 for months for all the devices . it hasn't changed even once so I had a doubt that probably the monitoring software itself is faulty.
darren-carr Tue, 11/11/2008 - 00:42
what do you get is you type 'sh env temp' at the exec? does the temperature show something different than the monitoring solution is displaying?
dany.datacraft Tue, 11/11/2008 - 01:22
Well, if you need to see the temperature change, you can try to disrupt the air-flow temporarily. For example, if it's a Cat6500 chassis, you can pull out the Fan tray for a few minutes. (Do it at your own risk).
Or you can turn off the air-conditioning in the server room for 15 min.
