What would you configure on a access port
Nov 11th, 2008
Hi guys,
I've been doing a bit of digging round Im trying to find what would be the best configuration to apply to my access ports in my environment.
I read things about flowcontrol, storm control, bpduguard, etc but am really unsure about what to apply?
As it is we have the ports defined as access ports, in the correct vlan, bpduguard enabled, spantree portfast, description, port-security, etc.
I want to ensure that all switchports operate optimaly, are protected, etc.
What else would people advise to enable?
Just throwing this out there for some suggestions and thoughts?
The devices I have at the access layer are 2960G, 3560E running latest IOS.
Thanks as always
Darren
satish_zanjurne Tue, 11/11/2008 - 04:27
  • Silver, 250 points or more
Hey Darren,
1.Basic requirement is as you already have mentioned
description
access port
portfast
bpduguard
2.port security is additional as per the requirement
3.I don't think so , that you will require flowcontrol for basic requirement , as both input & output flow-controls are off by default.
HTH..rate if helpful..
mahesh18 Tue, 11/18/2008 - 09:14
Try this command
switchport mode access
spanning-tree portfast
this way access port is config and also port fast
thanks
mahesh
darren-carr Tue, 11/18/2008 - 14:21
Thanks guys I had this enabled on the switchports already.
I've also added port-security to the access ports, with sticky enabled.
All is working well in the environment and Im now comfortable with the setup.
Cheers,
Darren
