IP communicator
j.huizinga
Level 6
Level 6
I have the following issue:
IP communicator runs as administrator, but not as a "normal" account.
It is security, but what security does IP communicator needs?
thanks,
JH
5 Replies 5
ebreniz
Level 6
Level 6
Similar problem described in bug id CSCsd20174.. IPC fails installs during startup, if logged in as non-admin on PC
that's a pretty old bug, all new releases have that fixed. what version are you installing??
java
if this helps, please rate
java
I am using 2.1.0 I see now that there is a new version.
I was familiar with the bug mentioned before.
I only want to know if there are specific read/write rights needed for IP communicator.
JH
yes, administrator or super-user rights needed
java
java
JH
