CME class of restriction.
Nov 11th, 2008
I have configured CME in 2821 router and it's working fine.The requiremet is to configure FAC in CME.I heard that it is called as class of restriction in CME.Could you pls help me out here how to configure class of restriction in CME.
thanks in advance
siva
Overall Rating: 4 (1 ratings)
sivakumar.kvp Wed, 11/12/2008 - 22:41
Thanks for your reply.I have Version 4.0(0)
Cisco Unified CallManager Express.when i hit 9 ,iam getting fast busy instaed of dial tone from PSTN.
Coniguration:
dial-peer voice 1 pots
preference 1
destination-pattern 9.T
incoming called-number 2767....
direct-inward-dial
port 0/3/0:15
forward-digits all
telephony-service
max-ephones 52
max-dn 192
ip source-address 10.126.234.254 port 2000
auto assign 1 to 192
calling-number initiator
url services http:///voiceview/common/login.do
url authentication http:///voiceview/authentication/authenticate.do
time-zone 39
date-format dd-mm-yy
dialplan-pattern 2 2767.... extension-length 4
max-conferences 8 gain -6
call-forward pattern 9.T
web admin system name cme password cisco
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern 9.T
secondary-dialtone 9
Looking for your suggestions.
thanks in advance
siva
allan.thomas Thu, 11/13/2008 - 01:41
  • Blue, 1500 points or more
I believe the problem maybe due to your telco? Can verify the status of your ISDN PRI controller.
There should not be any problem with the destination-pattern match, and I assume that you get the secondary dial-tone after you dial 9?
At this point the call should be routed off-net, however I assume there is a pause before you receive fast-busy?
Can you post the show controller output and show isdn status.
Can you also post a debug isdn q931 when you attempt an outbound call?
Hope this helps.
Allan.
Pls rate helpful posts.
sivakumar.kvp Fri, 11/14/2008 - 05:19
Thanks for replying me.There is no pause before i receive fast-busy.I'm getting fast busy as soon as i hit 9.Secondly the controller is down and isdn status is deactivated at the moment.I'm working with ISP as well.Will post you once the controller is up.Meanwhile can you tell me why iam not getting pause before i receive fast-busy.I wanted to double-check before iam going to customer on this..
looking for your suggestions..
thanks in advance
siva
sivakumar.kvp Fri, 11/14/2008 - 05:22
Additionally i wanted to clarify whether COR is same as call blocking feature.If not call blocking is used on date and time sequence to block calls..rite ? In this case is it like FAC ?
thanks in advance
siva
Jaime Valencia Fri, 11/14/2008 - 05:28
  • Cisco Employee,
  • Hall of Fame,
    2011
please do not duplicate your posts or keep them separated. you already have another one on the 9 busy tone. the answer is really simple, if you don't have ISDN up the as soon as dial-peer matches returns fasts busy because it cannot route the call.
FAC is not available in CME, this has been asked many many times before and there are a lot of posts on this. please use the search NetPro option for previous answers.
Unified Communications Applications: CME and FAC
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=Unified%20Communications%20Applications&topicID=.ee835d2&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cc17d46
just one of the many posts available already, please use Search NetPro option
java
if this helps, please rate
