CRS Editor - Check queue
Nov 11th, 2008
Can somebody help with the CRS Editor?
I want the script to check the queue size, and if the queue size is more than certain number I want to play a specific announcement.
What CRS Editor command should I use?
Aaron Harrison Tue, 11/11/2008 - 04:08
You can use a 'Get Reporting Statistic' step from the 'IPCC Express' palette.
Report Object: CSQ IPCC Express
Field : Contacts Waiting
Row ID : "CSQID" <-- your CSQ name or var
Result Stat : CallersInQueue <-- output variable
Then use an IF step to check
CallersInQueue > 5
Or whatever threshold you want.
Hope this helps
Please rate helpful posts...
