Giuseppe Larosa Tue, 11/11/2008 - 02:12
  • Hall of Fame,
    Founding Member
Hello Baajee,
be aware that aaa commands specify how remote control is done
aaa new-model
aaa authentication login default local-case
aaa session-id common
this tells allow access using local case sensitive username/pwd pair(s)
this specifies SSH version 2:
ip ssh version 2
! keys for SSH
cry key generate rsa general-keys modulus 1024
! encrypts passwords
service password-encryption
! useful command for troubleshooting keep them
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
! the VTP commands say this switch receives
! the vlan database from outside
vtp mode client
vtp version 2
vtp domain mydomain
vtp password VTPpassword1
if you deploy it in standalone change in
vtp mode server
this is the only change I would do at the beginning
check the line vty config to see what protocols are allowed (telnet and SSH or only SSH ?)
You may want to enable telnet in a lab environment.
a free SSH client
http://www.chiark.greenend.org.uk/~sgtatham/putty/download.html
Hope to help
Giuseppe
bishnbaajee Tue, 11/11/2008 - 02:35
Thank you Giuseppe....one more thing, i have to config two core (4500) switches and six access swithces (2960)in High availabity mode, in this case which one would be VTP server.
-baajee
Jon Marshall Tue, 11/11/2008 - 03:21
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Baajee
I would make your 2 4500 switches the VTP servers and the 2960 switches the clients. It is good to have 2 switches as VTP server for redundancy. When you want to add/modify/delete vlans you will only need to make changes on one of the VTP server switches.
Jon
bishnbaajee Tue, 11/11/2008 - 03:32
Thnak you Jon,
but I am planning to config both 4500 switches in active/active mode using GLBP. Will it work in that case..
-baajee
Jon Marshall Tue, 11/11/2008 - 03:37
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Baajee
Yes, the 2 are not linked at all. VTP is merely used to send vlan information to all switches. When you use VTP server/client setup it is a time saver in that you only have to create the vlan on one switch and that vlan is then available on all your switches. VTP works at L2 whereas GLBP is L3. The 2 can happily coexist on the same switches.
Jon
