WS-C3550-48-SMI ERROS
Nov 11th, 2008
I've been monitoring the 2 switchs WS-C3550-48-SMI
over the last couple weeks. Although there are no logs that give evidence, it appears there is something not quite right with these switches. From a monitoring tool that I have I can see interface resets on the Gigabit uplink port for some time now. There is a line under performance summary that states the number of state changes since midnight last night. I do not see this on the interface statistics (under carrier resets) but I have been notified of some complaints about poor performance on these switches. I can see the links are not overloaded so there must be a good explanation somewhere else up to and including something not related to the network
Please suggest me on the same
Regds
Adhi
Edison Ortiz Tue, 11/11/2008 - 06:44
  • Hall of Fame,
    Founding Member
Adhi,
Can you please provide the output you are seeing?
Perhaps you are experiencing duplex-mismatch in the configuration between the switch and another device or faulty cable.
__
Edison.
adhityakarthik Wed, 11/12/2008 - 02:44
HI
Thanks very much for reply
output is below
GigabitEthernet0/1 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 000e.38e4.5c31 (bia 000e.38e4.5c31)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive not set
Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseSX
input flow-control is off, output flow-control is off
Last input 00:00:00, output 00:00:11, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 273000 bits/sec, 462 packets/sec
5 minute output rate 4000 bits/sec, 4 packets/sec
34050999 packets input, 10981338 bytes, 0 no buffer
Received 30924958 broadcasts (0 multicasts)
0 watchdog, 23671238 multicast, 0 pause input
3115507 packets output, 859866121 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
i have cheked there is no duplexmatch could you suggest me
regd
Adhi
Edison Ortiz Wed, 11/12/2008 - 06:34
  • Hall of Fame,
    Founding Member
Adhi,
Based on the output provided, I don't see anything wrong with the switchport. I'm unsure what mechanisms your NMS tool uses to determine health on the switch but this interface is in good shape.
__
Edison.
