ICM script
Answered Question
I am using IPCCE with CVP 3.1 and I want to add this condition to IF node
if the call line ID start with xxxx then ....
I mean I want the function for (start with) it is not with the built in functions in the ICM script editor?
Correct Answer by Chris Deren about 8 years 8 months ago
The do the following:
1. In CLID step and use multiple prefixes for the same instance
2. Use If statment with OR (||) clause as following:
IF (left(Call.CallingLineID,3)=="123" || left(Call.CallingLineID,3)=="345")
3. Another option is uing Region node
HTH, Please rate all useful posts!
Chris
Overall Rating: 4 (1 ratings)
lpezj Tue, 11/11/2008 - 02:14
  • Gold, 750 points or more
I think that you have available functions similar to left, right or mid, in the same way as in a conventional programming language.
Take a look to it.
Hope this helps,
Juan Luis
Chris Deren Tue, 11/11/2008 - 11:42
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
I am assuming you are doing this logic in ICM script and not CVP Studio.
You have couple of solutions:
1. use the CLID step and use Prefix type and enter the CLID prefix
2. Use If statment as following:
left(Call.CallingLineID,3)=="123", where 3 implies you are lookin at 3 left most digits.
HTH,
Chris
Correct Answer
Chris Deren Wed, 11/12/2008 - 06:14
  • Hall of Fame,
Chris
david.macias Wed, 11/12/2008 - 23:00
  • Blue, 1500 points or more
Some calls will show up with no CLID and thus break your logic. Try having some logic which addresses where calling line id = "".
david
