CSC-SSM access via CLI
Nov 11th, 2008
Can the CSC-SSM module be configured via CLI. Or only GUI can be used.
Also is there any detailed configuration/Administration guide for CSC-SSM other than the document named "ASA: Send Network Traffic from the ASA to the
CSC-SSM Configuration Example
Document ID: 99141"
Overall Rating: 3.5 (2 ratings)
solpandor Wed, 11/12/2008 - 07:41
you can access the module via CLI by entering the command session 1 from the global config mode.
also, the main configuration is done via the GUI, (like which traffic to block etc). However, you will need to create a policy-map using the cli, match it against an ACL and then apply to the interface(depending on how you will using the CSC module) if you want to stop the inside users downloading files apply to the inside interface, or if you want to stop client uploading files via a web app then apply to outside interface.
HTH, please rate if useful.
