ASA 5510 + CME
Nov 11th, 2008
Hi there !
I have two branches that, for while, will not be connected to the main office.
But I have a CME in one and I have in main office an ASA5510 that is not being used (so I'll take it to the old branch).
Is it possible to create a IPSec tunnel between those two branches using CME and ASA5510 ?
The objective is to keep people that are moving to the new branch accessing the systems that are in the old branch while servers are not in the new branch (rest of the people will be moved in 6 month)
Thanks.
Andrei.
Overall Rating: 3.7 (3 ratings)
Brandon Buffin Tue, 11/18/2008 - 07:47
  • Purple, 4500 points or more
Andrei,
Yes, this is possible assuming you are running IOS with a feature set capable of VPN. It is not CME that enables VPN functionality, but the IOS on the router. Take a look at the following link for a sample configuration.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00805e8c80.shtml
Hope this helps.
Brandon
