WAE optimizing with Cisco ASA
Nov 11th, 2008
has anybody a configuration example or some hints for configuring two WAE and one CM connected to the ASA inside interface. The ASAs have an IPSec VPN Tunnel connection to their outside interfaces. Is it possible to configure promiscuous mode on the WAE? The services used in promiscuous mode are 61 and 62 on WAE, but it seems that this will nor work with Cisco ASA? I'm a bit confused how to configure this szenario because there are not even many config examples. Anybody some helping hands on this?
Best regards
Volker
owillins Mon, 11/17/2008 - 14:34
  • Silver, 250 points or more
WAE support for promiscous mode depends on the appliance and Not on ASA.
