Gateway MGCP with a VIC2-2FXS
Nov 11th, 2008
I have a Gateway 2801 MGCP with a VIC2-2FXS, well this gateway when run MGCP only detect one FXS in the UCM, I think that is a BUG
the first port
Cisco MGCP FXS Port Registered with x.x.x.x
the second port
Cisco MGCP FXS Port Rejected x.x.x.x
The Router Version 12.4(13r)T
IOS Router c2801-advipservicesk9-mz.124-22.T.bin
The UCM System version: 6.1.2.9961-1
Any suggestion for this problem??
Brandon Buffin Tue, 11/11/2008 - 07:48
  • Purple, 4500 points or more
Make sure you have both ports configured in the gateway configuration in CUCM under Device > Gateway.
Brandon
leandro.perez Tue, 11/11/2008 - 07:55
Yes I'm pretty sure
but I think is other configuration that fail
Jaime Valencia Tue, 11/11/2008 - 08:43
  • Cisco Employee,
  • Hall of Fame,
    2011
do you have dial-peers with application mgcpapp for those ports??
java
if this helps, please rate
leandro.perez Wed, 11/12/2008 - 10:47
Well friends this is a bug on the version the UCM System version: 6.1.2.9961-1
The MGCP Protocol when try to detect a FXS este falló. with two interfaces
thanks for help me
