CSM (load balancing) and Proxy_pac Bluecoat
Nov 11th, 2008
I have a probleme with a CSM configuration to upload from a PC a proxy_pac, here is the config I have:
vlan 5 client
ip address 10.255.5.6 255.255.255.0 alt 10.255.5.8 255.255.255.0
gateway 10.255.5.1
route 10.236.21.13 255.255.255.255 gateway 10.255.5.1
vlan 6 server
ip address 10.255.6.6 255.255.255.0 alt 10.255.6.8 255.255.255.0
gateway 10.255.6.1
vlan 329 client
ip address 10.255.29.34 255.255.255.0 alt 10.255.29.36 255.255.255.0
gateway 10.255.29.1
vlan 829 server
probe PROXY_PAC http
request method head url http://10.255.29.9:8081/accelerated_pac_base.pac
expect status 0 499
interval 8
retries 2
failed 10
port 8081
serverfarm PROXY_PAC
nat server
no nat client
predictor leastconns
real 10.255.29.23
no inservice
real 10.255.29.22
inservice
real 10.255.29.21
inservice
probe PROXY_PAC
And when a put the proxy in IE it stays stock.
Do you have any ideas ?
Do someone did expereience de same problems.
Cheers
Blaise
PS looking at the connections on the CSN doing a: sh module contentSwitchingModule 1 conns
I can see that the connections are established
drolemc Mon, 11/17/2008 - 07:11
  • Silver, 250 points or more
This problem may cause due to Network scanner device failure or sniffers. If any issues to report with regards to the scanner (on either chassis) to the virtuals/reals... Network scanner device flags the CSM's virtuals/reals as DOWN
