3750G monitoring & Stats
Nov 11th, 2008
I have two 3750G switches that are interconnected via the 32-Gbps interstack cable. I have done nthing special in regards to the configuration of the two switches that I would not do for a single standalone switch.
My questions are in regards to the stats that SNMP monitoring pulls. When I look at the switch stats am I seeing stats from a single switch or both combiled? For example the CPU Utilization is at 5% but Memory Utilization is at 80%. Also is there a way I can pull stats regarding the utilization on the stackwise cable? I would think server to server communication would cross the stackwise cable and the 27-Gbps backplane but it does not seem to to monitorable as sat one of the gig interfaces are. I am using Solarwinds ORION as a monitoring platform.
I am just trying to understand waht I am seeing before I worry about false positives and the like.
Brent
bberry Tue, 11/11/2008 - 13:18
Both switches are running ...
Switch Ports Model SW Version SW Image
1 28 WS-C3750G-24TS 12.2(25)SEB4 C3750-IPBASE-M
* 2 28 WS-C3750G-24TS 12.2(25)SEB4 C3750-IPBASE-M
I will check out the link .. thanks ...
teeboli68 Tue, 11/11/2008 - 19:33
good question... we are using Solar Winds Orion to do the same on stacked 3750's and the question of how CPU, Stackwise utilization, etc is represented never occured to me. I assumed one logical entity but if 2 ports on one stack member are doing all the talking then obviously only one of the CPU's in the stack of CPU's is busy. I guess it reports an average of all...
ropethic Wed, 11/12/2008 - 04:23
  • Silver, 250 points or more
Also, try rediscovering device using solarwinds. The stack-ring should come up as enabled interface. I have used solarwinds (10.0) and was able to monitor the stack.
bberry Wed, 11/12/2008 - 08:00
Does this show up as the Null interface? Unless there is something missing, I see my port channel, my regular interfaces and the null interface. Does it list something different under Solarwinds (10.0)?
ropethic Wed, 11/12/2008 - 08:42
Depending on the cabling, should show up as StackPort1 & StackPort2.
How do you have it cabled? top Port 1 to 2 , and bottom 2 to 1 ?
bberry Wed, 11/12/2008 - 08:55
We did not think it mattered when the went in since there are only the two so it is Stack1 to stack 1.
