WAE 4.1.1c upgrade failures
Nov 11th, 2008
I'm trying to upgrade my field WAE devices, from a software image on my WAE MC (WAE-512). The image is 4.1.1c, this was fine until I upgraded the MC to 4.1.1c, and now every attempt from the GUI or CLI (FTP COPY INSTALL command) fails. Both state the file maybe corrupt or truncated (I have deleted the source image, re-download a new one from Cisco and uploaded to the MC, with no improvement).
ropethic Tue, 11/11/2008 - 12:33
I had similar problems, when trying to upgrade form 4.013. I upgraded first all WAEs to 4.019, then the CM. I then upgraded the CM to 4.1.1b, and then the WAEs.
You have to upgrade to latest 4.0 before going to 4.1.
richianaj Tue, 11/11/2008 - 12:49
Thanks for your help, my MC was on 4.1.1b before so I don't think this is the cause of the issue.
ropethic Wed, 11/12/2008 - 04:27
Okay, try burning the image to a CD and reload and select last option ( I forget eitehr 7 or 8).
Once on CM, then try copy ftp install.
Richard Bradfield Tue, 11/11/2008 - 13:14
I have been upgrading from 4.1.1b to 4.1.1c
had no problem with downloading the software to the boxes
richianaj Wed, 11/12/2008 - 06:45
I should meantion that in further testing, upgrades to WAEs on the same LAN as the CM worked with no problem from the same software image.
