7906G and 7911G phones not recognised on CCM 4.1.3
Nov 11th, 2008
I am having a problem in that when I go to add a 7906G or 7911G phone on CCM 4.1.3, the phone type is not listed. Do I need to upgrade my CCM in order to get it to support these phones or can I download a device pack to support these phones on CCM 413?
Any help appreciated?
Derek
Derek McCormick Tue, 11/11/2008 - 09:18
Can I use 4.1.78 on CCM 4.1.3?
Can I go form my current device pack straight to 4.1.78
Derek
Jaime Valencia Tue, 11/11/2008 - 09:23
Supported CallManager Versions
This Cisco Unified IP Phone 7906G and 7911G firmware release is supported with the following Cisco Unified CallManager versions. If you are running Cisco Unified CallManager release 3.0, 3.1, or 3.2, you must upgrade to Cisco Unified CallManager release 3.3(5) or later before you install this firmware release.
•Cisco Unified CallManager version 3.3(5) SR1 or later
•Cisco Unified CallManager version 4.0(2a) SR2b or later
•Cisco Unified CallManager version 4.1(3) SR1 or later
also you need:
ciscocm.4-1-DevPack-25.3.exe, or later
Cisco Unified IP Phone 7906G and 7911G Release Notes for Firmware Release 7.2(3) for Cisco Unified CallManager 4.1
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7906g_7911g/firmware/7_2_3/english/release/notes/11R723sc.html
java
if this helps, please rate
