Xmodem - "Invalid Argument" on 3750
Nov 11th, 2008
I'm trying to transfer an IOS of my machine to a 3750 switch by XModem. I type the command below and after that, I select the file in my desktop in the HyperTerminal. It returned the message "Invalid Argument".
copy xmodem: flash:c3750-ipbasek9-mz.122-44.SE2.bin
dstecnologia Tue, 11/11/2008 - 09:57
Sorry Jon. I was trying to transfer the file using .bin at the end. I forgot it just on forum. It follows attached the images with .bin file on my machine.
viyuan700 Tue, 11/11/2008 - 18:23
at switch:
did you gave flash_init command before copying the file.
If not try it. This command initialize the flash and make it usable.i have attached a file which gives info about that.
dstecnologia Tue, 11/11/2008 - 20:28
Thanks! I was using the same commands of the guide, I changed the terminal emulation software and the trouble was resolved when I formatted the flash.
