VPN access to several VLANs
Nov 11th, 2008
My clients network is broken up by VLANs
VLAN 5,10,15, and 20
When I VPN in I can only access the native VLAN. So my server on 192.168.1.x, I can RDP to no problem. However, my server on 192.168.5.x, I can no longer RDP to. I cannot ping any address on VLAN5.
Something in my config changed because I was able to access all the VLANs via VPN.
What changed?? I have attached my config.
Thanks!!
John
Overall Rating: 5 (2 ratings)
ajagadee Tue, 11/11/2008 - 10:45
  • Cisco Employee,
John,
Your split tunnel configuration is allowing only traffic destined to 192.168.1.0/24 through tunnel. If you want to tunnel, 192.168.5.0/24, then you need to include this subnet in the Split Tunnel ACL.
split-tunnel-network-list value KWRE_splitTunnelAcl
access-list KWRE_splitTunnelAcl standard permit 192.168.1.0 255.255.255.0
Arul
*Pls rate if it helps*
ajagadee Tue, 11/11/2008 - 11:58
  • Cisco Employee,
John,
Glad to help.
Arul
