syntax differences in converting 6.x PIX to 7.x PIX
Nov 11th, 2008
Hi. I have a 5510 that I need to migrate a 515 config to. What do you suggest as the best way, manual or tool config migration? What are the syntax limitations of 6.x that I'll run into converting it to ASA friendly code?
srue Tue, 11/11/2008 - 13:26
interface configs, vpn configs, >7.x doesn't use conduits.
read the release notes for upgrading from 6.x
