Deleting hosts from LMS3.1
Nov 11th, 2008
I have 3 hosts that I see in RME Config archive, failed devices list. However when I try to delete them from either RME or Common Services, or Device Center I cannot find them, any ideas?
Mike Mott Tue, 11/11/2008 - 12:34
Yes it is integrated with ACS. The Hosts are not in ACS I have checked both by name and IP address.
Joe Clarke Tue, 11/11/2008 - 12:41
This is your problem, then. In order for LMS to be able to manage devices, they must be clients of the same ACS to which LMS is integrated.
At this point, you have two choices. The first is to add the missing devices as clients to your ACS server, then logout and back into LMS. The other is to temporarily break ACS integration in LMS. Both will then allow you to delete the failing devices.
Mike Mott Thu, 11/13/2008 - 09:51
Thank You Thank You Thank You. After recieving your response to my question I added the hosts back into ACS, and then got busy with something else. I just got a chance to look at CWSI to see if I could find the hosts. Sure enough they were there and I was able to delete them. Thank You! You Rock!
