Contingency Plan
John Blakley
I've attached a document for everyone's review to get your thoughts on it.
A rough summary is that I've got a load balancer that all of our internet connections come into. I need to have a plan in place to be able to throw something up quickly to get our internet back up.
A couple of questions:
I think I'm going to have to NAT the traffic for the 2.2.2.0 and the 3.3.3.0 traffic for the 1.1.1.0 subnet. Is this configuration that I've come up with feasible for an interim fix should the load balancer go down?
Does anyone else have a better suggestion (aside from redundancy). I don't think we can get another load balancer.
Thanks!
John
HTH, John *** Please rate all useful posts ***
Okay then yes your solution seems a good one as as intermediate until you get a new fatpipe although it is worth discussing with your boss that you will not be able to fully utilise all the links and that the cost of a fatpipe might well be covered by the amount of money you lose by not being able to utilise all the links. I realise i could be talking rubbish here depending on the cost of a fatpipe (no idea) and how you pay for bandwidth on your links.
One thing to be aware of. If you are going to NAT to 2.2.2.x and 3.3.3.x you obviously can't use the "ip nat inside source list interface fa0/0 overload as it will use the primary address of the interface ie. 1.1.1.1 so you will need to define a pool for the 1.1.1.1 and the 2.2.2.2.
Other than that it should be fine. Would be interested to hear if you ever have to use it ?
Jon
11 Replies 11
John Blakley
Here's a better "aligned" pic.
Jon Marshall
John
Difficult to say without understanding how the load-balancer does what it does. What is it actually load-balancing for ?
Also when you mention NAT what traffic are your Natting ?
Jon
Well the addresses that are on the load balancer are all publicly routable addresses. The load balancer really does nothing more than allowing all of our traffic in and out. The 2.2.2.0 and 3.3.3.0 are natted in the current device, so I figured I'd have to nat on the router for those subnets as well.
It doesn't load balance in the traditional sense; it's just where our internet connections terminate.
-John
Ah okay. Do you know if the load-balancer has 3 separate interfaces then, one for each network or whether it is just interface.
Are the 3 different ISP's responsible for the 3 different IP ranges because it's still not clear how these links from the ISP to the load-balancer works in terms of addressing.
I ask because you may well not need a router. If it is just a question of NAT you could just use your firewall.
Congrats on the new star by the way :-)
Jon
Thank you! It made my day ;-)
It's a Fatpipe, and it has 3 separate NICs. We do have 3 different ISPs coming into it. We possibly could use the firewall, but it's not Cisco unfortunately, so I'm not sure how to set it up.
--John
If it has 3 separate NIC's then i think you are right to go with the router but i'm not sure how the router will utilise all the links. I suspect your fatpipe is doing more than just terminating the links.
The 1.1.1.0/2.2.2.0/3.3.3.0 networks - are they used to present internal addressing to the Internet for servers that people off the Internet access ?
When your users go out to the Internet which of the above networks do you use to NAT their source IP addresses - assuming you are using private IP addressing internally.
Jon
They go out 1.1.1.0, and the firewall actually does that natting outbound. All of our locations come through us for internet access. We can force connections out any one of those links in the fatpipe, but I don't think I'm going to be able to do that in the Cisco (aside from PBR).
This isn't meant to be a total replacement, but it's more of a "in the meantime" interim replacement until we got a replacement load balancer should that one go down. I wouldn't be as concerned about internet traffic out as I am with connections coming in from the outside.
--John
Sorry not trying to be clever or difficult but i am still not understanding what the 2.2.2.0/3.3.3.0 networks are used for. If all outbound traffic is Natted to 1.1.1.1 then unless you are using 2.2.2.0/3.3.3.0 to NAT internal servers why do you need to NAT them at all for this temporary solution.
Jon
1.1.1.0 is our main internet connection
2.2.2.0 is our "backup" internet connection (but we have dns pointing to this block as well)
3.3.3.0 is our "backup-to-the-backup" and it's primarily for a certain department to use.
The fatpipe has all three public addresses on three different interfaces. The primary lan interface is on the 1.1.1.0 subnet. When I force traffic out 1.1.1.0 network, then I tell it not to NAT, but when I force traffic out the 2.2.2.0 network, I tell it to NAT.
You're not being difficult. =)
--John
Jon
Yeah, I'm hoping never to have to use it. I'm sure once I tell them that this looks like the plan, we'll schedule an outage on the weekend to test it.
Thanks again Jon!
John
