about call manager 6.1
Nov 11th, 2008
I have to migrate the data from the existing call manager which is 4.2(1) ... to a new server that I have installed call manager 6.1(2)... whats the best way to migrate all the data from the existing box to the new box?
Kind regards
Rachel
Overall Rating: 5 (4 ratings)
allan.thomas Tue, 11/11/2008 - 15:38
  • Blue, 1500 points or more
The direct upgrade from CUCM 4.x is possible with the DMA (Data Migration Assistant) tool.
DMA migrates data for Cisco Unified Communications Manager and Cisco Emergency Responder, as specified in the following sections.
DMA assists you with the first step in migrating Cisco Unified Communications Manager data from supported versions of 4.x to Cisco Unified Communications Manager 6.1(2) by exporting this data in a format that Cisco Unified Communications Manager 6.1(2) can read
The above is taken from this document:-
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/dma/6_1_2/dmaug612.html
For supported Cisco Unified Communications Manager Upgrades for Release 6.x and Release 7.x take a look at this doc:-
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp40524
Hope this helps.
Allan.
Pls rate helpful posts.
Rob Huffman Tue, 11/11/2008 - 15:43
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Rachel,
Just to add a note to the great tips from my friend Allan (+5 points for this Allan :)
You will need to be at CCM 4.2(3) to use the DMA Tool to migrate the data from 4.x to 6.x;
Check out the compatibility here;
Table 4;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp1533139
The DMA Tool is available for download via CCO Software Downloads;
Data Migration Assistant User Guide Release 6.1(2)
Obtaining DMA
If you do not have DMA software on a disk, perform the following steps to download it to the Cisco Unified Communications Manager publisher server. Only a registered user of Cisco.com can download this software.
Procedure
Step 1 Go to this URL:
http://www.cisco.com/pcgi-bin/tablebuild.pl/callmgr-61
Step 2 Select DMA file.
Step 3 Follow the prompts and provide the required information to download the software.
This is the actual download link;
http://tools.cisco.com/support/downloads/go/PlatformList.x?sftType=Unified+Communications+Manager+Data+Migration+Assistant&mdfid=281023410&treeName=Voice+and+Unified+Communications&mdfLevel=Software%20Version/Option&url=null&modelName=Cisco+Unified+Communications+Manager+Version+6.1&isPlatform=N&treeMdfId=278875240&modifmdfid=null&imname=&hybrid=Y&imst=N
Via these steps from the Software download site
Voice and Unified Communications > Cisco Unified Communications Manager Version 6.1 > Unified Communications Manager Data Migration Assistant > 6.1(2)
Hope this helps!
Rob
rachelau_2005 Tue, 11/11/2008 - 15:46
Hi Alan
I have read the document, it says that
"You must install and run DMA on the Cisco Unified Communications Manager publisher server before you upgrade to Cisco Unified Communications Manager 6.1(2). "
However I have already installed the unified communication manager 6.1(2) ... so does that mean i have to rebuild it from scatch using the DMA ?
kind regards
Rachel
Rob Huffman Tue, 11/11/2008 - 16:09
  • Hall of Fame,
    Founding Member
Hi Rachel,
Great question! Sadly you will need to re-build to new box choosing the Widows migration option :(
Even with the new build of CCM 6.x on a new box you can choose the Windows Migration option using the Data Migration Assistant (DMA). Just run the DMA on the old CCM 4.2(3) before you start and it will produce a .tar file that can be used to move the data across to the new version;
Import Windows Data
This option allows you to import database information from a Cisco Unified Communications Manager 4.x system by using a file that the Data Migration Assistant (DMA) tool produces.
Upgrading the First Cisco Unified Communications Manager Node
When you choose Windows Upgrade, the installation wizard prompts you for the location of the preexisting Windows configuration information that the Data Migration Assistant (DMA) tool created. See the Data Migration Assistant User Guide for more information on the DMA tool.
Step 1 - In the Windows Upgrade window, import data from a Windows version of Cisco Unified Communications Manager by choosing Yes
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/upgrade/6_1_1/upgrd611-pdf.pdf
Hope this helps!
Rob
allan.thomas Tue, 11/11/2008 - 16:27
Hi Rachel,
Thanks for answering this one Rob, on the ball as always. (+5 points)
Probably not the advice you were looking for Rachel :(, but unfortunately as Rob has highlighted the Windows migration option is only possible during the upgrade or new installation.
Best regards
Allan.
allan.thomas Tue, 11/11/2008 - 16:55
Hi Rachel, no problem we're all here to help. Thank you for the rating, and good luck with the re-build.
Allan.
rachelau_2005 Tue, 11/11/2008 - 16:42
Hi Rob
Thanks so much again!!! :) I follow the procedure and try again.
Kind regards
Rachel
Rob Huffman Tue, 11/11/2008 - 17:00
  • Hall of Fame,
    Founding Member
Hi Rachel,
You are most welcome :) Best of luck with your new upgrade.
Cheers!
Rob
allan.thomas Tue, 11/11/2008 - 17:05
One other thing to mention. Is it possible to remove one of your disk mirrors from your existing Publisher in order to replicate the Publisher on another server?
The reason for this, is that it will enable you to run DMA during normal hours without affecting your Production Publisher, otherwise you will have run the DMA OOH I'm afraid.
Hope this helps.
Allan.
