krishanmistry Wed, 11/12/2008 - 09:45
I assume you can just change the IP address on the server that the WCS is running on without having to unistall and reinstall the software.
I would recommend backing up the WCS database before making any changes.
You may also have to reassosciate the controller with WCS because of the SNMP traps.
Good luck
