11-12-2008 12:19 AM - edited 03-06-2019 02:25 AM
Is it possible to create a switch-stack like with 3750 switches. Or is there only the way to configure a cluster but every 3560 switch has it's own config. Is there something to see all 3560 switches in one overview so there are 3 modules in the config.
Solved! Go to Solution.
11-12-2008 12:41 AM
Hello Marcus,
C3560 is not stackable as the C3750, it misses the special stackwise cable 32Gbps that makes stacking 3750 efficient.
in C3560 configuration guide for release 12.2(46)se the last one there is no section about stacking.
However, it is possible to manage a group of 3560s using clustering
this is different from stacking, but from a management point of view provides a single access to all the cluster members.
Hope to help
Giuseppe
11-12-2008 12:41 AM
Hello Marcus,
Hope to help
Giuseppe
