Ship-to-shore wireless
Nov 12th, 2008
I want to enable wirless connections for data transfer from boats when they arrive in port. I'm thinking of using a mesh network to cover the quay areas back to the main office and either use mesh nodes or access points on the boats themselves. I'll need an antenna either side of the boat to ensure coverage. Will I need two access points (mesh nodes)on the vessel or can I connect two antennas to the left and right diverity ports on a single device. ANy thoughts on whether to use mesh nodes or APs on the boats?
krishanmistry Wed, 11/12/2008 - 09:40
depending on which way the boat docks and its size will determine how many access point you will need.
I would recommend mounting an AP on each side of the boat to cover the above scenerio, and having the Root access point mounted in an ideal location on the shore.
I feel you will be better off with Mesh unless your in the US and can use the 1400 bridge APs, the the Mesh APs they will auto discover themselves and will determine the best root back the the RAP.
Hope this helps
To have a single AP and multiple antennas will work for short distances however the moment to move over 10 meter from the AP with an antenna extention cable you will start to loss alot of signal in the extention cable.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
