"show ip sla statistics" output
Nov 12th, 2008
Hi, I got the following output, which is different from that in the command reference. The "Number of successes" here appears to be the number of measurements that is below threshold. It doesn't mean the successful of the measurement.
I would like to check the definitions of the outputs of this command. Please advise.
>sh ip sla statistics details
Round Trip Time (RTT) for Index 1076888578
Latest RTT: 347 milliseconds
Latest operation start time: 12:07:38.129 GMT Wed Nov 12 2008
Latest operation return code: Over threshold
Over thresholds occurred: TRUE
Number of successes: 0
Number of failures: 21
Operation time to live: Forever
Operational state of entry: Active
Last time this entry was reset: Never
Joe Clarke Wed, 11/12/2008 - 07:52
You are correct. The number of successes is the number of operations that complete with an "ok" result code. The definition of an "ok" result is:
"A valid completion occurred and was timed successfully."
Over Threshold means:
"A valid completion was received, but the completion time exceeded a threshold value."
