Add a C3750G-48TS to a C3750G-24T stack...
Nov 12th, 2008
Hi all,
I added a C3750G-48TS to a stack of two C3750G-24T switches.
The new one is running IOS c3750-ipbase-mz.122-35.SE5
The two older ones are running IOS c3750-ipbase-mz.122-25.SEB4.
After I plugged the stack cable I got the following message:
Nov 12 13:45:09: %STACKMGR-6-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has changed to state UP
Nov 12 13:45:09: %STACKMGR-6-STACK_LINK_CHANGE: Stack Port 2 Switch 2 has changed to state
Nov 12 13:45:14: %STACKMGR-6-SWITCH_ADDED_VM: Switch 3 has been ADDED to the stack (VERSION_MISMATCH)
Nov 12 13:45:14: %STACKMGR-6-SWITCH_ADDED_VM: Switch 3 has been ADDED to the stack (VERSION_MISMATCH) (math-switch-1-2)
Nov 12 13:47:14: %IMAGEMGR-6-AUTO_COPY_SW_INITIATED: Auto-copy-software process initiated for switch number(s) 3
Nov 12 13:47:14: %IMAGEMGR-6-AUTO_COPY_SW:
Nov 12 13:47:14: %IMAGEMGR-6-AUTO_COPY_SW: Searching for stack member to act
Nov 12 13:47:14: %IMAGEMGR-6-AUTO_COPY_SW: as software donor...
Nov 12 13:47:14: %IMAGEMGR-6-AUTO_COPY_SW: Software was not copied
Nov 12 13:47:14: %IMAGEMGR-6-AUTO_ADVISE_SW_INITIATED: Auto-advise-software process initiated for switch number(s) 3
Nov 12 13:47:26: %IMAGEMGR-6-AUTO_ADVISE_SW:
Nov 12 13:47:26: %IMAGEMGR-6-AUTO_ADVISE_SW: Systems with incompatible software have
Nov 12 13:47:26: %IMAGEMGR-6-AUTO_ADVISE_SW: been added to the stack. The storage
Nov 12 13:47:26: %IMAGEMGR-6-AUTO_ADVISE_SW: devices on all of the stack members have
Nov 12 13:47:26: %IMAGEMGR-6-AUTO_ADVISE_SW: been scanned, and the software required
Nov 12 13:47:26: %IMAGEMGR-6-AUTO_ADVISE_SW: to make all stack members compatible with
Nov 12 13:47:26: %IMAGEMGR-6-AUTO_ADVISE_SW: each other was not found. The "archive
Nov 12 13:47:26: %IMAGEMGR-6-AUTO_ADVISE_SW: download-sw" command can be used to
Nov 12 13:47:26: %IMAGEMGR-6-AUTO_ADVISE_SW: install software off of the network from
Nov 12 13:47:26: %IMAGEMGR-6-AUTO_ADVISE_SW: a tar file.
Is there any way to fix it without going there with a serial cable?
10x a lot!!
Naor
glen.grant Wed, 11/12/2008 - 04:38
  • Purple, 4500 points or more
If the master is the 12.2.35 version then just do a copy from switch 1 to the other incompatible members in the stack and then reload the slot . Make sure your boot statement is correct.
Joseph W. Doherty Wed, 11/12/2008 - 05:48
For a quick fix, and not 100% positive, but a reload of the stack might make the newer IOS version member the stack master and cause the other switches to run the newer IOS. (Longer term, you should get the same image on all the member switches.)
ropethic Wed, 11/12/2008 - 06:08
  • Silver, 250 points or more
It has been my experience that that the master does not load the latest version of IOS. You will need to copy over the 12.2.35 to the other switches and reload. I tried the exact scenario a couple of times with IOS not getting copied over to the other switches. I had to manually tftp and chenge boot to new image.
