Configuring 3 lines in a single Ip phone
Nov 12th, 2008
We have Cisco 7941 Ip phone
We need to configure three Directory Numbers on a single IP phone which belongs to different partition.
Is it possible to configure in Cisco7941 model?
Kenneth Mohammed Wed, 11/12/2008 - 06:09
  • Silver, 250 points or more
Is this CUCM or CME. If you have CME, this can be done by creating overlay extensions on the phone. If you have CUCM I'm not sure that this would be possible.
Hope that helped. If so please rate.
Jaime Valencia Wed, 11/12/2008 - 07:23
  • Cisco Employee,
  • Hall of Fame,
    2011
you say partition so i assume this is CCM/CUCM
let's do the math. the phone has 2 lines, and you want to configure 3... doesn't really sound doable don't you think???
the answer is NO, you cannot configure more lines on the phone, than the phone is able to use.
the phone can be configured for up to 2 lines, if you need 3 lines get a 796X phone
java
if this helps, please rate
